ayjay »
https://forums.nicoclub.com/ayjay-u5495.html
Sat Feb 07, 2004 12:15 am
i'm assuming that the subs have dual TWO ohm voice coils each... so if you run the subs in series and bridge them on the amp you will get your 2 ohm load... i think that's the best you can do, cause otherwise you'll be runnin a 0.5 ohm load with both subs in parallel bridged and not too many amps are stable down to that low...
for the 2 ohm load you'd want, on each sub, connect the POSITIVE from one of the coils to the NEGATIVE of the other coil (series connection)... once you got that done, then you connect the left over NEGATIVES from each sub to each other, and the left over POSITIVES to each other, and bridge the amp... you'll get two ohms out of this configuration...
SO when looking for an amp for these subs, look at it's RMS power output at 2-ohms, try to get one that puts out AT LEAST 600W @ 2ohms... IDEALLY you would get an amp that puts out 2000W @ 2 ohms, and that's a hard find, but U.S. AMPS has their 2000X amp that will do 2000W RMS at 4-ohms bridged , which you could run by just running your subs in series... eBay has em' going for around $500 US, and I don't know what your budget is like, but that amp is sick my friend! :puke
for more info on bridging your subs, go HERE , and if your subs are dual 4-ohm voice coil, it explains how to run a 1-ohm config, giving you the most power...
