i need help once more, lol
rhd itr
Car: 97 nissan pathfinder
alright, so i just replaced my control arm. And i was trying to torque the nut onto the lower balljoint assembly, but it seems that the bolt that im trying to torque the nut onto spins freely. I was wondering if anyone knows how to put it on?
timmack
Car: 2002 Nissan Pathfinder SE
did you try with the car up in the air or on the ground? you gotta have the vehicle weight on the ball joint to properly torque it.
timmack
the bolt is actually a wedge shape therefore the weight of the vehicle pushes it down into the hole.
rhd itr
timmack wrote:did you try with the car up in the air or on the ground? you gotta have the vehicle weight on the ball joint to properly torque it.
i tried to torque it while i had it jacked up off the ground. Are you sure that its safe to lower the car back down when the nut is not secure on the bolt?
SnowSurfLax
Car: 1999.5 Infiniti QX4
2006 Infiniti M35 Sport
Yup. FSM states you need to have the vehicle under normal load (more than hafl full gas tank, someone sitting in driver seat, all jack components in place) in order to correctly torque any of your control arms.
W O T
Car: 2001 Infiniti Qx4
Def gotta be on the ground
timmack
yep its safe. i did mine that way on both sides and havent had any issues. i went to retorque it and it was right at where i originally tightened it.
rhd itr
thanks so much for the help guys. i really appreciate it
