BuudWeizErr »
https://forums.nicoclub.com/buudweizerr-u1639.html
Thu Jul 29, 2004 2:44 pm
then you don't understand the construction of coilovers vs a spring and shock combo.
the spring will come down a lot farther on the shock body on a set of coilovers, and the whole overall assembly is generally slightly shorter, so even though the springs are wrapped much tighter, you still loose a ton of offset space, dependent upon the size of the shock and the diameter of the spring coils.
