ziggy682 »
https://forums.nicoclub.com/ziggy682-u3095.html
Tue May 10, 2005 3:36 pm
All you have to do is adjust the rod that attatches to your clutch pedal. There is a lock nut on the rod, loosen it, then turn the rod to adjust where the clutch engages in the throw. You will probably have to play with it a bit to get it where you want it, but it's super easy.
