float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Sun Jan 02, 2005 6:50 pm
First of all, I'm with TMS on this one, I think you shelled the transmission.
MikelZ: A shift lock is a term used to describe a method used to initiate a drift. The way that it is performed is that you approach a turn in a higher gear (generally 3rd/4th). As you reach the turn you turn the wheel, depress the clutch, shift to a lower gear (2nd/3rd), and quickly release/"pop" the clutch. The shock of the downshift is transfered through the drivetrain and causes the rear tires to break loose. The rest is just regular drifting (aka: NOT smaking into a curb)
