I need help oil on my spark plug
drifter183
can any 1 help me out? i took out my spark plug out of my #1 cylinder and oil was driping off it my friend told me there is a gasket around the spark plug and i need to chang it but some 1 else told me it could be my piston ring what do u think it could be???
thanx
big jon's 240
Car: uh....football, cars, and um, cars!
Usually a oily plug means you have bad rings or bad valves/ valve seats. Does your car smoke while its running? There is no "gasket" around you spark plugs. What do the rest of your plugs look like?
1dollar240
If you have a SOHC, then this could be a problem, if you have a DOHC, then its probably just an o-ring, take off the valve cover and check it out.
drifter183
all my other spark plugs look fine. Were is the o-ring at is it the 1 around the spark plug? thanx for your reply's
drifter183
oh ya and it dosent smoke while running.
1dollar240
It would help us all answer your question if you would answer whether or not you have a 89-90 or 91+ 240sx
drifter183
its a 1991 240sx se
1dollar240
ok, then its most likely just the simple o-rings that hold oil out of the spark plug socket, its kinda hard to explain but if you just pull the valve cover off then you will see what I'm talking about. it seals the valve cover to the head around the plug.
Gladimor
Car: Girls, cars, Girls, mountain bikes, oh and Girls
Well then it's not that bad of a leak, hopefully it's nothing more than a bad piston ring try upgrading to a higher weight oil, it will slow the process until you can put the engine under the knife. Also there is a product that napa sells called seafoam, you can add it to your crankcase and it helps seal the pistons.
Peace
stickgoat
Valve cover gasket... replace it. :)
Turb0wned
buy a valve cover gasket thats your problem i had the same thing and i just finished replacing mine it was in the #3 spark plug that was all it was the gasket was only $15
Unnatural
big jon's 240 wrote:Usually a oily plug means you have bad rings or bad valves/ valve seats. Does your car smoke while its running? There is no "gasket" around you spark plugs. What do the rest of your plugs look like?
There is a "gasket" around the spark plug on DOHC engines. It is actually around the base of the spark plug 'tube' in the valve cover.
Like the others have said these O-Rings can leak on higher mileage cars and can make a real mess. Just buy a replacement valve cover gasket set (make sure it includes the tube seals). Remove the valve cover and you'll have access to the tube seals to replace them.~Brendan
Nismo_Freak
Car: 89 Nissan 240SX
Simple fix... get some rotary plugs!
Hahha...
J/k... replace that gasket.
