I need help! Manual Trans problems!
xoxide
I need major help!
Alright thursday, I did my 5 speed swap on my S14. Put a lightly used Spec stage 2 clutch in, and I believe a stock pressure plate. I put the throwout bearing in that was originally in my coupe but still spun freely.
Anyways, yesterday when I put it in first and start to let off the clutch I get this really loud grinding whine sound, if I put it in neutral, it still would make the noise, until I let off the clutch completly. then it would stop. It will do it in 1st, 2nd, reverse, and im not sure whatelse. I pulled the transmission (drained the fluid and it was very dark and mettalic, the plug had metal shavings on it to), transmission seemed bad. so I replaced the trans with another trans today... I got it all back together still with the same throwout bearing and clutch. Took it for a testdrive around the block and it worked fine, then when I went to leave after cleaning up, it immediatly started making this really bad whine/grinding noise again.
what could be wrong? Throwout? Clutch? Im really getting bummed about this... dont know what to do?
kouki munster
Car: 97 base 240
Change your throw out bearing.
PapaSmurf2k3
Site Admin
agreed.
alms24sebring
'04 Nissan Sentra SER SpecV
Always change your throwout bearing. It comes in a clutch kit and is a rule of thumb to change it so you dont have to take it all apart again if it goes bad.
Lobo240sx
Car: 1991 Nissan 240sx Coupe SR2.35DET Redtop Build
Yeah my friend learned the hard way too by not changing it out. Come to find out he had a brand new one ready to be put on. :facepalm:
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
If you gotta pull it all back out I would do a clutch kit just because something else may be failing soon
