I need help m35 system
Post all your Nissan electronics, car audio and stereo questions here!
Supra2k
Car: 2008 M35 Sport
I need help getting the wires into the trunk from the backseat. from the truk it seems everything is welded and blocked off with metal plates. DO i drill a hole or must i remove the back piece of back seat?.
this is for the 2008 m35.
also does anyone know of the best lowering springs that give the biggest drop?
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
Those don't look to fun to work on because of the power rear seat option. There's got to be a grommet to get all the wiring to the trunk, and knowing Nissan I'd guess it's on the driver side somewhere so that's where I would start looking.
Supra2k
Car: 2008 M35 Sport
K i got evething wired now. only problem... where's the hole in the firewall to get to the battery? Anyone know?
PoorManQ45
If the hood latch is a mechanical lever there is almost always a grommet that it goes through that is large enough to poke a 4awg or 2awg through.
What components are you putting in the M?
Supra2k
Car: 2008 M35 Sport
JL 12w7 1000/1 Amp.
the converted
Car: '99 BMW M3 6.0
'20 Toyota Tacoma
Nice.
PoorManQ45
what speakers?
the converted
Car: '99 BMW M3 6.0
'20 Toyota Tacoma
I'm guessing stock?
PoorManQ45
dear god I hope not. That w7 in a properly designed enclosure will easily do 130dB.
The stock speakers might be able to hit 105dB
the converted
Car: '99 BMW M3 6.0
'20 Toyota Tacoma
I have two 6" subs with 120w that hit 135 db on music, I sure as hell hope that a w7 with a THOUSAND WATTS puts out like a prom date in comparison.
PoorManQ45
exactly! This is why I hate helping people that are onlyu adding a sub to a fully stock system. It is a totally lopsided setup that sounds like arse.
What 6" subs do you have, and where were you measuring that output at?
I have 2 TC sound 12" db-500s in my station wagon. They have ~22mm one way xmax. On my radioshack dB analog meter it registers 120dB. But the meter is insensitive at low frequencies. So it's actually much higher.
The thing is, my main speakers can hit 118dB on this meter. So it's not a lopsided setup
the converted
Car: '99 BMW M3 6.0
'20 Toyota Tacoma
measuring at the windshield per comp regulations. JL 6W0's. Does your ratshack meter read in dba or dbc?
I don't understand why you don't like to help people if they are only doing a sub. It all comes down to personal preference in what they want to hear as I know you have said many times before. The person who adds a huge sub today is probably doing an amp and 4 a few months down the road anyway.
PoorManQ45
true, but i usually like to ask if theyre installling speakers later. If not then it turns me off to helping them. I'll give them a little advice, but I wont pay too muvh attention.
I'll check my meter later
Supra2k
Car: 2008 M35 Sport
im upgrading my speakers in a few weeks, just got the car. I'm rewiring my sub to the rear door speakrs tomorrow.. bc the bose decreases the sub as volume inrease... anyone know what wires to tap into? There's a 20pin plug in the trunk. DO i tap it into the Purple wire ?. Thanks..
the converted
Car: '99 BMW M3 6.0
'20 Toyota Tacoma
Bose decreases the bass through ALL the speakers as volume increases. Does the M have a sub volume control on the deck? Probably your only way to compensate.
PoorManQ45
Converted: Is there an adaptor for that model that allows usage of an Aftermarket HU with the bose amps?
If so, that would get rid of that bass reducing feature
the converted
Car: '99 BMW M3 6.0
'20 Toyota Tacoma
you have nav in the car?
