LinkNuc »
https://forums.nicoclub.com/linknuc-u77126.html
Fri Feb 06, 2009 9:14 am
Make sure you have the polarity of the battery correct, the side with the writing (flat side) faces down when the battery is in its slot...also try putting the key fob in the key fob slot...and starting
That warning you are speaking of is the SECURITY INDICATOR LIGHT....it might be that your fob needs reprogrammedpage 2-25 of your manual
Security indicator lightThe security indicator light blinks whenever theignition switch is in the OFF, LOCK or ACCposition. This function indicates the NISSAN VehicleImmobilizer System is operational.If the NISSAN Vehicle Immobilizer System is malfunctioning,the light will remain on while theignition switch is in the ON position.If the light still remains on and/or the enginewill not start, see a NISSAN dealer forNISSAN Vehicle Immobilizer System serviceas soon as possible. Please bring allregistered keys that you have when visitingyour NISSAN dealer for service."
I sent you an email...
