Ok so I'm in the middle of an s14 sr20 swap into my sr. I got the dash connector repinned, and Im almost done sleeving everything, but Im missing a few plugs. I dont know if they were cut off or ripped off.
The first one is a purple/white &black wire. According to the FSM, the purple/white is to the power steering oil pressure switch, and the black is obviously ground.
Second: I think there's 3 wires to this one. I say that because they are all cut/ripped at about the same length. The wire colors are red,brown, & orange/black.
If anyone knows what these go to, and which(if any) connectors I can steal of the ka harness to be able to get these working, please let me know. This is really all that's keeping me from finishing this swap.
Thanks alot!
edit:
I found this page:http://zilvia.net/f/engine-tech/293028- ... guide.html
I know its for an s13 sr, but I think its the same. It says the power steering thingy majig isn't needed. Is this right?
and it looks like the other plug is to the Turbo Boost Pressure Solenoid, and again it says not needed?
if all of that is true, that still leaves out the red, which Im guessing is a constant power wire
