I need help identifying these wires
cole d
Car: 93 S13 conv
I need help identifying these wires I started this engine swap last yr and I'm just getting everything ready to go back in. I had to send off my wiring harness for it to be modded (1jz swap) and I'm not sure I received everything back. I've installed the wiring harness on the engine and have identified all of the engine bay connectors that connect to the engine harness (I think). I took a picture of these connectors that I have left over I'm not sure where they belong a little help would be nice.
Thanks
Chris
If its something simple I apologize but I'm getting close to finally installing this engine
2 prong connector
black wire/ white stripe
black wire/yellow stripe
2 prong connector
brown wire/ white stripe
black wire
solid black connector
white wire**
green plug ?????
cole d
Car: 93 S13 conv
Also have questions about these 2 connectors this was something the bodyman moved and I don't know what they go to. These are on the passenger side near headlights
biggie
I suck at wiring. Hopefully someone will be able to help, if not we can move it to the 240 Tech section.
cole d
Car: 93 S13 conv
My buddy just looked at this post and told me I am indeed missing the the positive side battery cable(duh). Which explains black plug with the white wire and the green plug. I still need to know what the bigger 2 prongs plugs are?
biggie
One could be the park/neutral switch that's under the passenger's side fuse box.
motaro9424
Car: 240sx convertible
pic#1
2 prong connector
black wire
.IT IS FOR THE A/C FAN
The another next to this, it is the ac dryer sensor(or pressure sensor)
and the green and black connector going to the ++battery .one is for the alternator and the another one for the starter
pic #2 just look for the anoter connector, they are coming from the firewall.where the computer wires coming out.but i guees u dont going to need because u doing a swap.
s13beast
Car: 94 5spd silvert S14 SR
91 hatchback dd
The two near your headlight are for the fuel pump and other stuff. You gotta wire the two ka plugs that connect to them into your new harness.
cole d
Car: 93 S13 conv
Thanks for all the help guys I need to source another battery cable since my stock one was lost. I also need to find a junk 240 and replace my a/c wiring.
