I need help getting the sr to start!!
sms240sx
I have got all of the basic stuff hooked up to make it run, it tries, but wont start. I dont have the intercooler piping installed, would that cause it to not start? I've got the wiring by the battery hooked up, the fuel pump is working, and the coil packs are firing, and the timing is set. Let me know some other stuff to keep it from running and I'll let you know if I have already done it.
240_Keyy
Car: '90 240 Fastback
nope, it won't run unless the IC piping is hooked up. it sees that as an IMMENSE boost leak :D
BuudWeizErr
You don't have your IC piping hooked up and you expect it to start? Come on man. Go buy some of that thick dryer tubing if you have to to run it for a little while.
sms240sx
Ok, I got the piping from the turbo to the throttle body run, does the maf sensor need to connected to the turbo? BTW, does the KA maf sensor work on this swap, or would I need one from a 300zx TT? I have a single turbo 300zx if that one would work.
240_Keyy
uhhhh... I think the SOHC MAFS will work, any others and you have to have an SAFC to compensate for the added flow...
BuudWeizErr
Man, what are you doing piecing an SR20 together from old spare parts?
An SOHC KA AFM will work, but you need the plug off the KA wiring harness for it.
Cyberkreig
Car: 1993 Nissan 240SX SR
yeah, the SOHC maf will work but needs a rewire. you cant use that 300zx without an ECU retune.
MojoMan
Car: working on cars and women
Jesus Fui(kin Christ!!!.........What tha Fu(k are you doing. Go buy a honda if your not gonna do your research and blow it up while your at it. ooyy......people like you......Dammn! My head is hurting. Im sorry that was harsh. Just do alittle more research.
Rican_Nick
good luck man.. u need piping, u need afm as stated above ka sohc afm will work.. once again GOOD LUCK!
ride4lame
you could be more specific too.... anyway, i couldn't wait to see if my sr would start, so i started without the intercooler piping sealed(missing a coupling or two) and it runs for a few seconds before stalling...
