mpbclutch33 wrote:Sorry I can't get the video to work, so I will try to explain.
Alright, this is not for my A/C, but my girlfriend's Jeep. Her system worked fine for years and recently it started to cut out. It is not overheated, it has something to do with the RCA's. When you push on the white RCA, the subs hit, let go and they don't. Then sometimes while driving, it will stay on for a good while before cutting out again. I can't tell if it is the wires or where the RCA's connect inside the amp.
I had an almost new Kenwood KAC-7252 Amp and I tried to hook that up to her system and the power light comes on 'red' and the fan comes on, but no sound. I am not sure if the light is supposed to be red or if that means it is in 'protection mode'. If it is, is there a way to reset it? None of the fuses on the amps or the power wire is broken. I know that it can be a hairline fracture, so I replaced them and still nothing.
it could be the RCA's or maybe not the RCA's themselves, but the RCA inputs on the amp, or the RCA outputs on the headunit.
I've had audio systems in the past where BOTH of those went bad. If its the RCA outputs on her headunit, then the headunit needs to be fixed or replaced. If its the RCA inputs on the amp, then the amp needs to be fixed or replaced.
Usually, the protection light on your amp won't come on just due to lack of a good signal (from the headunit's RCA's or from the amp's RCA's inputs) but rather due to a problem in wiring. if its somehow wired too low at the woofer. THis could happen if, over time, the internal wiring comes loose on a dual voice coil sub, but this doesn't seem to be the case in your scenario.
I'm confused by your last line.. did you replace your RCA's or not. If you replace your RCA's, and the problem persists, then again its either the RCA inputs on the amp, or RCA outputs on the headunit.
Audio shops would first test your amp by removing it, hooking it up on a bench to another headunit and testing it on a woofer. If you have a spare headunit you can quickly hook up the power and ground wires to your battery, and then run the RCA's from there to your amp, and see if the problem persists. If it doesn't, then you know its the rca putputs on her deck. If it does, it is most likely the rca inputs on her amp.
