i need help ! anyone plz
nismo guy
Car: spec v , 240sx
i have a 91 240sx with the ka24de and i had to replace the master and slave cylinders for the clutch i did and bleed it and i still have no clutch pedal falls straight to the foor i need help i tried replaceing everything and bleeding forever dont know wat else to do
spindrift187
did you bench bleed the master cylinder?
nismo guy
Car: spec v , 240sx
yeah i bench bleed it and i think the throw out bearing and clutch is out iam going to replace them and see if i get pedal then
crookedcop7
Car: 89 nissan sileighty
this is an easy fix from the master clyinder follow the line 2 the slave there is a box (forgot the name of it) if u bypass the box u will have ur clutch backhad the same problem (its by the slave)
spindrift187
clutch dampener, yank it out and CAREFULLY bend the line to fit. costs nothing and supposedly helps with pedal feel(ive never noticed a difference).
nismo guy
Car: spec v , 240sx
thanks im going to try it ! also iam very new to 240s and ima turbo the ka any ideas on the ecu i should use and the injector swap can i use sr20det injectors or is there a specific type i should use the ones i was thinkin about r 370cc
