IvoryJ30t »
https://forums.nicoclub.com/ivoryj30t-u9485.html
Tue Dec 23, 2003 7:42 pm
ok, under the hood there are two rubber hoses that go to the firewall [the firewall is the plate of metal at the very back of the engine compartment, that seperates the motor from the passenger compartment]
those hoses look exactly like the radiator hoses, but smaller.
you see, the heat in a car is made by the hot engine coolant. thats why you dont get heat untill the engine warms up. the heater core is just a miniature radiator that heats the air in the passenger compartment.
warm the car up to normal temperature, then put the heat on full blast. feel if the heater core hoses are warm/hot. if yes, then you have to check if the air control door is operating.
when you switch from "cold" air to "hot" air, you should hear the door clunk. if it doesnt, that could be the culprit. the dash needs to be disassembled inorder to access it.
