I NEED EXTENDED WHEEL STUDS for an 89-94 240 the nismo ones wont work!
erollinc
where can i find some i need them badly i did a google search and didnt come up with jack
please help!
Why won't the NISMO ones work? They work on all S13 hubs.
Dan at Midway has them, call him, tell him you're from NICO.
Chingon
Car: 1991 and 1992 hatchbacks
xterra or frontier. Something like a buck fifty..
HKSpeed
apparently there are 2 different bolt head sizes for 240's. all s13's are the same front & back. s14's use the same s13 rear bolts, but some fronts require a smaller bolt head. so there are 2 different sizes availalbe (13.X and 14.X mm). i think it has to do with being 4 or 5 lug. not sure. thread and pitch are the same for all. i know H&R and nismo makes both sizes.i found this out after i bought some 15mm H&R spacers that came with extended lugs.
st33f
Car: 1990 240sx - redtop sr20det, T04B/T28 hybrid, UG coilovers, 3inch turbo back
pepboys had extended ones when i went there... no joke.
All nismo studs for the S13 are the same. Period.
S14 are different (a little thicker in the spline area).
I was not aware of the Frontier / XTerra studs, I will have to buy one and check them on my spare hubs. Good find!!!!
OK, just did some research:
From 1997-2005, ALL Frontier and XTerra models use the same lug studs. And none of them are close in length to the 60mm size of the Nismo studs.
Back to the drawing board!
erollinc
thanks alot yall i relaly appreciate the help.... yeah i had the s14 nismo ones and the spline section was too wide to press into the hub
erollinc
got em from car quest
j-z
Car: 95 240sx
yeah i found out the hard way about the s14 studs this weekend. the fronts are bigger in the spline area like greg said. i needed a rear one, so i went to reed nissan like always and picked one up. well, the fucher behind the parts counter screwed up and gave me one for the front which is bigger. i find this out after i already tried my damn hardest to get the stud to go in and ended up stripping a new lug nut i just bought and made the whole in my hub bigger. i went back up there to get the correct one, and ended up stripping that one because the hub hole is now too big for the correct one. now i dont know what im going to do. prob drill it out and put a front stud in that hole. BUT first im going to try and get nissan to pay for a new hub. thanks for ruining my entire weekend you fuchwad at reed!!!!!!!!!!!!
Gotta do your own research, the guys at the parts counter aren't experts.
I have an S13 rear hub if you want it.
