I need dimensions of the stock crank pulley
float_6969
I'm trying to put AC back in my car and I can't find my stock crank pulley to save my life. I need to know how far out the front face of the pulley is away from the timing cover, or if someone had a crank pulley off the motor, the distance from the front face, to the rear face. I DON'T need the overall distance including the part where it attaches to the crank.
dhen
Car: MGA w/ CA18DET
Do you mean with both pulleys or just one?
dhen
Car: MGA w/ CA18DET
The crank pulley on my car only has one but I've seen pictures of two.
float_6969
It should look like this;
That is the RWD CA18DET non-HICAS crank pulley.
float_6969
float_6969
Nobody can run a tape measure out and measure their stock crank pulley for me? There's been a bunch of views on this thread.
dash
Car: s13 ca18
from the front face of the front ring, to the rear face of the third(inner) ring measures; 2.218 inches
is that what you're after ?
float_6969
Yes! Thank you!!!
