i NEED Diagram for Fuel Lines on KA24DE
new_to_drift
Car: 89 240SX coupe
Hi i just had to swap a DE motor into my coupe cuase the sohc motor blew.And The motor is in and everything is hooked up except the fuel lines, there are 2 or 3 which i have no idea where they hook up to.I need a diagram of where each fuel line goes or a picture of a actual engine bay pic of the fuel lines, that would be even better.PLEASE HELP.
IveBeenBad
Car: 1990 Nissan 240SX Fastback STOCK BIOTCH
no pic but its simple... the line from the fuel filter goes to the rail w/o the pressure regulator. the other line goes to the rail with the pressure regulator
GCIA4LIFE
Car: '93 240SX
KINDA OLD POST (REAL OLD)im new to the 240sx so bear with me, i swapped in a ka24de into my car and everything is hooked up right and timed prety good as i had a mechanic come ova n do it But my car will almost start but die than just not turn ova, BUT SOUNDS LIKE IT NEEDS gas, the engine kinda smells of gas also,i have the fuel filter line going to the pressure regulators,im gonna fix it tomorro, but could this fix my problem'>?
