busteds13 »
https://forums.nicoclub.com/busteds13-u56647.html
Fri Mar 05, 2010 8:16 am
My dropping resistor is dead, im sure, i recentley lost injector #4 . at firs i thought i lost coil #4 but i swapped amongst cylinders, plugs too, and #4 was still dead, then i swapped ignitors, so now i have an extra one. Anyways, i pulled injector plug #4 and got no change in idle, so i pluged injector plug #3 into Injector #4 and it clicked all sortsa healthy, so i swapped an old Dropping resistor i had with the swao when it arrived originally that im sure had tested bad, im not sure, the same injector is still dead. Immona doublecheck both Droping resistors to be sure, but is it common for #4 do poop itself?
the idea is this, i want to eliminate the droping resistor entierly as a singular unit, and just harwire each injector with its own 5 ohm 50 watt resistor from rat shack, so when they inevitably fry themselves ittl be easier to change, rather than go look for a part that seemingly no longer exists anywhere? also for redundancy and simplicity? i feel like ive heard of someone doing this before, but im not sure.
