I need an ECU.....
crxcess
Car: 93 240sx fastback
Like the title says I need an ecu, a cheap one.
My original problem was that cylinder #5 was not firing. While I was testing the ignitor the car just shut off and wouldnt start. So I replaced the ignitor and now the car runs again,but cyl #5 stll is not firing. So that leads me to belive my ecu is the culprit. Yes, I did check the wires... no, they are ok.
So if anyone has an ecu laying around, hook me up.
Thanks,
[email protected]
goofynick6
Car: 1995 S14.5 RB20DET
Bad injector? Coil pack?
crxcess
I swapped coil packs around and still the same cylinder missfired. I pulled out the rear coil bank and set it on the valve cover with plugs installed, Cyl #5 had no spark. even after swapping coil packs around.
sam
BoostFab
Car: S13cp, S13fb, S14z
i have an auto-ecu if you want? email me.
crxcess
I still need an ECU if any one has 1...
BoostFab
i have the auto one, if you still want it
burnin240sx
maybe its a wiring issue?
Imissmyturbo
Car: Car's, Turbo's, sking
I am in Lancaster PA and I have two extra ECU's RB25's. Not sure if thats what you need or not but that's what I got. If you want to try one out let me know. It's about 1 hour drive from you.
skwertle
Imissmyturbo wrote:I am in Lancaster PA and I have two extra ECU's RB25's. Not sure if thats what you need or not but that's what I got. If you want to try one out let me know. It's about 1 hour drive from you.
I need a rb25et ecu. is it a series 1? Please email me at [email protected]
thanks
crxcess
I just bought one off boostfed... thanks anyway.
burnin240sx
HOW MUCH FOR A RB25DET SERIES 2 ECU?[email protected]
Imissmyturbo
The one I have works fine and I would like $150.The other on works but the tach output from the ECU doesn't work. $75
crxcess
boostfed,
thanks the ecu worked out perfectly....The car goes with light throttle but if i floor it ,it sputters. could be old gas or that old ecu might have fried another ignitor.
BoostFab
crxcess wrote:boostfed,
that was quick
afaik the ecu should works fine....there probably something else is causing the problem......is all 6 cylinder firing? maybe try to check the diagnostic code from the ecu again to see if it 's returning any error?
crxcess
im going to mess with it some more this weekend, it could possibly be a fuel problem... I only have the dump pipe installed and with moderate revs it was shooting 6 inch flames out...
this is the 4th rb20 swap i have done in the past year, no other has give me as much problems as this one.
as soon as i finish this swap im going to sell it....tired of this thing.
