churro »
https://forums.nicoclub.com/churro-u58562.html
Thu Aug 16, 2007 4:06 pm
By "chamber," I assume you mean camber? Pull off the wheel and check if anything is bent. If something is bent hope its just an arm and not the subframe. Best scenario is that you need an alignment.
Also I think there is some special washer that can get messed up and will show these same symptoms.
