audtatious »
https://forums.nicoclub.com/audtatious-u2438.html
Mon May 30, 2005 4:38 pm
Atlanta is in da House!!! What area?
Ok....
1. Factory rims are only 7" wide, so that limits the tire options. 245's are out of the picture as they are too wide. 235's are not within spec either, but others have used them with no issues.
2. Best bet would be a junk yard to find a wrecked I35 for the grille.
3. You can take the calipers off the car and paint them which is preferred, but too much work. You can mask off everything and paint the calipers that way, which is what most others do. I have known some that took the high-temp paint and sprayed it into the lid, then apply the paint with a paintbrush (they said you could not tell they did it that way) which would be the simplist way to do it.
120mph.... Isn't that normal traffic flow on 285 during pre-rush hour?
