I Need A Total List Of Parts For Installing Q45 Brakes On 4 Lug S13
rico05
Car: 1992 RMS13 w/ CA18DET
Picking up a set of Q45 calipers this weekend. What all is needed to install these? I know that I will need new pads and redilled rotors (to 4x114.3 pattern). Will the caliper bolt up to the stock bracket? Will they fit under wheels with +22 offset? Can I still use my Goodridge SS lines? Thanks for the help.
93RPS13
Car: Cars, Girls, Cars, Food
go to http://www.ka24delevopment.com stock lines of for the 240sx will work with the Q45, bolts to stock brakets, redrill the rotors yourself rent a press drill,
i would also like to know if that offset will work??
93RPS13
o and brake fluid too, that would be important :D
rico05
Awesome. Thanks a lot. I plan on using Brembo slotted rotors, Axxis Ultimate pads and Motul DOT 5.1 fluid. I'll give a review once I have them on.
Nismo_Freak
Car: 89 Nissan 240SX
Brakes are at the shop now. :)
The S13 is almost complete, just need the engine mount and water hoses.
93RPS13
where did you get your rotors??
rico05
eBay is where I will get em;)
93RPS13
remember i want some pics too, i plannin to do it on my soon to be S13....
whiterps13
Car: white LE hatch
just curious why you chose this setup over the 300zx tt? was it the price?
93RPS13
i think is because of the price and everthing, q45 is a daul sliding piston caliper with 11" rotor with a 28mm thickness... as the Z32 brake upgrade 11" rotor with either 26mm or 30mm rotor plus you dont need new lines or MC
Dori Dori
Car: Cars of course
What's on the rear of the q45? Does it have a drum style parking brake like the z?
93RPS13
yea that what i heard, has anyone solved the Z rear brake cable problem with the swap???
USsil80
if i am not mistakin aren't they the same as the jdm 180sx brakes
93RPS13
no there not because the i believe that a maxima caliper w/ a altima rotor or something
Dori Dori
Car: Cars of course
Dori Dori wrote:What's on the rear of the q45? Does it have a drum style parking brake like the z?
Anyone?
CaptainHenreh
Yes. The Q45 rears are the "drum in disk" style parking brake. Like, the 300Z, or the subaru SVX.
Not worth it in my opinion, but apparently it can be installed without the 5 lug swap, I was reading about it on FA.
Something involving a larger nut. I wasn't really paying attention.
Holisticbeatz
Brake clearence is based soley on wheel and spoke design, not offset!
Dori Dori
Car: Cars of course
CaptainHenreh wrote:Yes. The Q45 rears are the "drum in disk" style parking brake. Like, the 300Z, or the subaru SVX.
Thanks. I don't think it's worth it either. I'm just trying to figure out how to get a larger rear rotor without going through that garbage.
CaptainHenreh
Maybe...M30? Or J30 perhaps. *thinks* As far as I know, all of the rear-drive nissans that have bigger brakes than we do use the drum-in-disc...
Maybe an S15, though?
There's a thought.
Dori Dori
Car: Cars of course
I believe JDM S14's and S15's used the exact brake setup as the z32. I know they do in the front, but I'm not 100% about the rears. It's definately something worth looking into.
C-Kwik
Holisticbeatz wrote:Brake clearence is based soley on wheel and spoke design, not offset!
Wrong, for a given wheel and spoke design, offset can be the difference in whether or not it will clear. I have 4 17x8 Konig Villains. 2 will clear my Z23 brakes, 2 will not. the 2 that fit have a 30mm offset. The ones that dont have a 40mm offset.
