bvanfossen »
https://forums.nicoclub.com/bvanfossen-u18549.html
Thu Nov 04, 2004 6:25 pm
i have a '93 j30 w/ 103,000 miles. i have replaced the timming, water pump, fuel filter, tps & cleaned the mafs, both throttle bodies ( ever since the day i cleaned the mafs and tb's the car has idled high, 1000 rpms!). i have also had the injectors cleaned- twice! i have tried many different fuels- moblile, chevron, ect... no difference.
it hesitates only in the first 1/4 of the throttle during acceleration and only in low rpms. @ 2,000 rpms @ 40 mph seems to be the spot where it will constantly hesitates as long as it's in that range. but it doesn't do it all the time- only intermittenly. it also seems to do it more often when the tank is halve full or less. i changed the tps tuesday night. weds, & thurs. morning it ran awsome- the pedal feel was great through the rpms. it seemed like the old tps was having problems in the lower rpm's. on the way home thurs night, i felt the hesitation again- and i noticed the gas gauge was under 1/2 tank. please help!!! i'm going to fill up tomm and see if that makes a difference.
this is driving me crazy!!!!! thanks all that reply !!
