I need a loooooooong relay kit.
BlackNWhite
Car: 08 Altima Coupe
*Adds to the collection of HID-related threads*
Ok guys. I don't want to go through all that bull**** required to wire my fogs with splicing and all that good stuff. Since My HIDs have a relay... my passenger side OEM factory harness connection is empty. I need a relay kit that connects directly from the battery and is long enough to connect to the PASSENGER side OEM factory harness.
I'm going to use this and run HIDs down to the fogs. This should work right? However, all HID relay kits I've seen, connect on the driver side. They are all very short and come no where close to connecting through the passenger side.
I remember one person said they got a relay kit with their Xentech kit and they connected it to the passenger side because it was long enough. But this was a long time ago and I don't remember who it was.
Help?
BlackNWhite
Damn, I thought I would've had some responses. Anyone???
l33th41
Car: 2010 Nissan 370Z
2010 Mazda 3
That was probably me. I purchased my relay kit here: http://motors.shop.ebay.com/me...pgZ25
It came with an extension that i used to run to passenger side.
BlackNWhite
Ok, I'm screwed then. I bought my relay from this exact same person... and it didn't come with an extension.
Maybe yours was a fluke and it wasn't supposed to have an extension?
I'm going to message the seller. Thanks.
BlackNWhite
Anybody else have ideas?
bina12834
Car: 06 G35 coupe
BlackNWhite
Bina... this seller looks the same as the other one.
You ordered from this person and it connects to the OEM factory harness through the passenger side?
bina12834
Car: 06 G35 coupe
oh....na....i connected mine to the driver side headlight.....most relay kits wont be long enough to connect to the passenger side headlight unless you make it yourself. youll most likely always have to lenghten the positive and negative wires on kits that you buy.
BlackNWhite
bina12834 wrote:oh....na....i connected mine to the driver side headlight.....most relay kits wont be long enough to connect to the passenger side headlight unless you make it yourself. youll most likely always have to lenghten the positive and negative wires on kits that you buy.
Lmao, BINA! That's what this whole thread is about man. Thanks for the help though.
