I need a little help with the MAS connecto 94 Q45
Mr.Q45a
Car: 1994 Q45, 1995 Q45a
Hi
I have not been on the is board for long time and things have really changed and it looks like there are a lot of new members which is nice to see
I need a little help with the MAS connector
Yes my 94 q45 shakes and stalls at lights but when I pull over and fiddle with the wire and connector the problem is immediately rectified
I recall from a few years back that others were having a simular problem. But I have unable to find the mod or repair suggestions because of all of the changes
Furtherer. I believe that Joe at midway had come up with a replacement part or fix
I could use your help and suggestions
Thanks for your time and consideration
96Qowner
Car: 1996 Q45
I don't mean to be all grumpy and point out what you should have done, but if you had looked a few more threads down the page before posting, you would have found this:
zerothread/251215
You're always free to use the search button, as well. Hope I was some help to you.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Did you try cleaning it first?
Mr.Q45a
hello,
thank you everyone for your helpful information
Yes I did clean the mass airflow sensor and the connector and then applied liberal amounts of electrical grease to all connections
At this point I believe it is either the pins within the connector or more probably a broken and cracked wire leading to the sensor
Thanks again
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
01 B15 Sentra (Daughter's)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
hey Quash-sounds like your connector needs reworking--theres a post or two with the info for the kit, i show kent-moore j-38751-112 (shell), -123 (qty 3 terminals), and -124 (qty 3 seal).
if you can solder, it's easy diy. just be real careful to maintian the correct order of the pins or you'll fry the ECU. oh, and uncork the battery first....
