i need a fwd water pump pully
capwred
does anyone have a fwd pully i can buy?i got the 1988 pulsar water pump new from a friend and i need a pully for it.
DjLiquid
Car: 1988 Nissan Pulsar
i own a fwd and rwd and I can tell you that besides the clutch fan, the pulleys are the exact same so you don't need one specifically for the fwd
GoofyATX240
Actually they are different. The RWD hole is a tad bigger then the FWD pullies hole.
pulsar gtr
Car: NISSAN VEHICLES
If you are still interested, I have couple FWD pullys. [email protected]
Cheers,
RafiPULSAR GTR
float_6969
DjLiquid wrote:i own a fwd and rwd and I can tell you that besides the clutch fan, the pulleys are the exact same so you don't need one specifically for the fwd
A while back we had A BUNCH of members who tried to use RWD pulley's on FWD pumps and I think every member ruined the pump. The difference is enough that it kills the bearings on the pump and causes it to fail.
If you're using a RWD pully, you need to use the pump off of a CA18ET from an S12, otherwise, if you use the FWD pump, you've GOT to use the FWD pully.
capwred
th[QUOTE=float_6969]A while back we had A BUNCH of members who tried to use RWD pulley's on FWD pumps and I think every member ruined the pump. The difference is enough that it kills the bearings on the pump and causes it to fail.
If you're using a RWD pully, you need to use the pump off of a CA18ET from an S12, otherwise, if you use the FWD pump, you've GOT to use the FWD pully. [/QUOTE
thats what i have been told by some people that tryed it.so im going to use a fwd pully.
DjLiquid
wow, sorry about the bad info :S.
I was looking at both and I never saw a difference =/... I think I need glasses =(
capwred
en=
pulsar gtr wrote:If you are still interested, I have couple FWD pullys. [email protected]
Cheers,
RafiPULSAR GTR
email sent
