I need a Engine for my 98 Frontier
TheTinMan
Hey, i through a lower rod bearing.... Does anyone know where i can get a engine that will fit a 98 frontier XE 4x4, 5 speed?? that has low mileage, and not to expensive? If so please call me at 425-238-6777 or by Email at [email protected]
Thanks, Matt
Big-Bird
Car: 2000 Xterra on 'Roids & 2004 Quest SL
your best bet is to find a local wrecker that might have what you seek.
there are so many Frontiers out there there is always a few lying around that are just dying to donate their motor. I believe any 5 speed VG33 from a Pathfinder, Xterra or Frontier should work.
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
The one in my '98 is from a wrecking yard. It's a 2000 engine that had 21k miles on it.
The 4 bangers from any 98-04 should bolt and plug right in.
If the donor had an auto, you'll need to swap over your flywheel, and 4wd vs 2wd used different oil pans and pickups, but they interchange just fine.
