long story short.my car is a 91 California model, which had an exhaust temp sensor. the engine in my car is a non california model, which does not have an exhaust temp sensor.
after I put in the 91 motor w/o the sensor.. i got a check engine light.. didn't think anything of it since when I started it.. the light came on, went off...came on..went off.. so i looked under the hood and forgot to hook up some intake hoses and stuff.. then the light just stayed on...figured it was just that.
well.. i finally figured out that I could check my ecu to figure out the problem code... came up with two.exhaust temp sensor (california model)and detonation sensor.
so here I am driving around with an ECU that thinks I have some problematic sensors that do not exist in my car.(the detonation sensor may or may not be bad.. its my knock sensor..which costs like 140bux from nissan)
soooo... i'm hoping that someone out there who has done an SR swap, or CA swap into a 91-93 5 speed has an ECU laying around.
anyone help?? please!i hope we can work something out..
my car is running like crap...and i've changed so many things..but yet no fix!i'm hoping its just the ECU.. only thing I can think of now.
-Dan
