I must be missing something (outter tie rod?)
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
GahannaKid
Replacing my outer tie rods and I can't seem to get the tie rod off the steering arm. Everything (that I can see) has been removed, the nut holding the tie rod in place (that sits on top of the steering arm/spindle) has been removed, and I have my rubber mallet but nothing is separating the two. Is there something I'm missing? Seems like an easy enough job, read some guides, watched some videos and thought I was ready to go.
noface
Car: 1985 Nissan 720 4x4 King Cab
you have a pickle fork right?
Get a real hammer, and don't be afraid to smack it HARD.
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
I unscrewed the nut til it was level to the end of the bolt, jacked up the LCA and hit it once with a hammer.
GahannaKid
noface wrote:you have a pickle fork right?
No pickle forks. I used the remaining PB Blaster on it last night, tried again this morning and in my hungover rage was finally able to get them out. The passenger side came out no problem, the driver side on the other hand [shakes fists in anger]. Unfortunately with the Ohio weather these tie rods are basically fused in place, I'm searching for a heat gun to see if I can't make them easier to unscrew.
I hate it when easy jobs are made difficult. This is why I ask for tools every Christmas.
flinterman2000
Car: 2000 Nissan Wingroad, 85 Datsun 720 Pick Up.
Easiest solution. Get a pickle fork and a 2 pound ball pean hammer. Don't be afraid to hit it hard.
dogred
Car: 1983 D720
A local parts store should have a frontend service kit you could rent.
GahannaKid
Thanks, but I got em out awhile ago. I need to replace the ball joints next, those are going quickly + I have a brake fluid leak in the drivers side rear wheel that I need to find & fix.
Return to “Datsun 720”
