evildky »
https://forums.nicoclub.com/evildky-u13100.html
Wed Jun 29, 2016 9:17 am
Welcome to NICO, and congrats on the Z!
The Z31 is a pretty dependable car even at 30 years old.
If you don't know when the timing belt was last changed, change the timing belt! These are interference engines and if a belt snaps the repair bill just skyrocketed, and just because it was done 20k miles ago but 6 years, do the belt, they are made of rubber and deteriorate over time even if they see very little use.
All other belts and hoses, are also 30 years old unless they've been replaced, the radiator sits at an angle inside the nose and is a PITA to replace but with an older car if it hasn't been replaced don't be surprised when the car starts to run a little hot.
Hot air from the dash, the heat and air are controlled by vacuum and dashpots under the dash. might be as simple are replacing a cracked vac line might nee to replace the dashpot bellows under the dash.
Bushings, again it's a 30 year old car, the rear crossmember bushings are the most problematic as the t top drain tubes pour water on top of them shortening their lives, a real pita to replace, all the other bushings are also 30 years old so keep an eye out for them.
Rust, it's not unique to this model but it's the number one killer of Z cars, and it like roaches, what you see is only a small fraction fo what's hidden!
The power steering uses Dexron type atf. Often someone wiht a tiny leak adds the regular power steering fluid which is much thinner and that tiny leak gets much worse, fast.
CHTS, when the car won't restart when warm it's the chts or the wiring pigtail that leads to it, pretty common issue.
These cars are now 30 years old so there will be some oddball failures, the PTU (or ignitor) if fairly common, cas (inside the distributor) seems to be getting more common, ecu, mas have been known to randomly fail as these cars age
If the car has been garaged and cared for many of the age related issues may not pop up or might have been handled by a good previous owner. a Ragged otu car that lived it's life outside and was neglected will definitely need a lot more attention and most of the age related issues are likely to pop up.
