I messed up.... Help with a couple of connectors.
walleyealx
Car: 1991 TT Z32
I pulled the plenum and put the new injectors in along with new plugs. I've gotten it almost completely back together but I made the mistake of not labeling my wires. Luckily the previous owner had labeled the coil pack wires and injector wires so that helped a lot. I've got a few connectors that I can't find a home for. I made a video to see if any of you could help identify if they need to be plugged in or what goes where or if I have something wrong. (if you can tell from the short video.)
Thanks ahead of time.
https://youtu.be/F-grarhwNiw
walleyealx
Car: 1991 TT Z32
Looking at this stock wiring picture it definitely seems that those two wires that won't reach are not even supposed to go there. The one that hooks to the throttle sensor must be buried.
walleyealx
Car: 1991 TT Z32
I've got everything hooked up I think correctly other than F6. I I can't seem to find the oxygen sensor connector anywhere and I can't even locate the oxygen sensor even with pictures, LOL.
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
The connector most likely fell down the back of the engine. May be easier to find from the bottom, honestly. Just look at an angle from the area of the brake booster and look between the engine and the firewall, and you should see the O2 sensor at the top of the downpipe. Just trace the wire from there.
walleyealx
Car: 1991 TT Z32
I used a little gun bore camera and found the bastard wedged in the back. Crisis averted.
Ace2cool
:dblthumb:
