i made a new song for fans of jungle?
Musicians and music-related topics are all right here in the Music Room.
scotttak
Car: 2018 Camaro ZL1
not sure what id catagorize this into
http://soundclick.com/share?songid=8084947
make sure ur subs are on and the speakers turned up!
scotttak
no takers?
C-Kwik
Its not jungle. Way too slow to be. And dimensionally different. If that's a purposeful intent at creating jungle/dnb, then you need to listen to more of it. If you don't understand what jungle/dnb is, then you need to listen to more of it. Bottom line, listen to more jungle and dnb.
scotttak
yeah i just didnt know what category to place it under. i dont listen to too much electronic music. im more of a progressive metal fan, but thought id try to make something different.
Red coupe
Car: 92 Nissan 240sx Coupe
C-Kwik wrote:Its not jungle. Way too slow to be. And dimensionally different. If that's a purposeful intent at creating jungle/dnb, then you need to listen to more of it. If you don't understand what jungle/dnb is, then you need to listen to more of it. Bottom line, listen to more jungle and dnb.
agreed, more people should try harder to fit their music into well structured categories so it doesn't accidentally sound original, that way you can make sure people like it because they have basically already heard it.
scotttak
lulz
scotttak
has anyone else tried playing this in a car with subs??? makes mine bump like crazy and i dont have them set that high.
dickie
Car: Killer Turtle
music room.
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
Not what I would say is jungle. Needs more work. Are you just layering loops in FL? Or did you program/sequence it yourself?
scotttak
im using fruity loops sounds and generators but all the notes are put in the piano roll by me.
breadbox
89 Koop
84 720 4x4KC
Good deal. I liked your other stuff better.
scotttak
my older songs that i have on there concentrate more on the actual notes and not much on the instruments. these new ones im trying to concentrate more on how its sounds than the notes being played.
Return to “The Music Room”
