fiznat »
https://forums.nicoclub.com/fiznat-u1372.html
Sun Jun 11, 2006 5:38 pm
Searching will help alot for this, but in general:
Burnt ECUs: Simple, plug-and-play- you dont have to modify them at all once they're plugged in. Two major companies offer them for our cars: JWT (Jim Wolf Technologies) and Enthalpy. Both cost about the same (about $500). You send them your ECU and info on your setup, they send you back the ECU with your tune. Minuses are that if you make a significant upgrade, you have to re-burn the ECU as well, which often is not cheap.
-Piggybacks: Products like the SAFC will "piggyback" onto your stock wiring and modify signals so that you add more fuel when you need it, etc. These are usually pretty rough around the edges and not reccomended for a high horsepower car like you are planning. Also, the SAFC for example only controls fuel-- so you need to buy something else (like a MSD BTM) to control timing as well. These units are cheaper, though.
-Advanced Piggybacks - Products like the E-Manage fall into this catagory. They work similarly to the SAFC (by acting as an intermediatary between your engine and the computer, "tricking" the computer into adding more fuel or reducing timing when you need to). These units are capable of fuel as well as ignition timing, give you a much nicer layout (plug into a laptop and give you full maps)-- but they still have some significant weaknesses that are inherent in the piggyback design. There are lots of complaints about emanages if you look around, although it is true that this system really isnt THAT bad for the cost. Also there is a new Emanage Ultimate that is more of a hybrid piggyback/standalone which is supposed to solve a lot of the original Emanage ("emanage blue") issues. Cost for the blue emanage is I beleive about 500, for the ultimate I think its closer to 700 once you're done with all the harnesses and stuff. Someone correct me on that if I'm wrong.
Standalone- The ultmate management. Something like the AEM EMS or a Haltech/Motec system is a complete ECU replacement (and in the haltech's case, complete wiring replacement as well -- the AEM EMS by comparison just plugs in where your old ECU was). These systems can do absolutely anything you can dream of- custom fuel and timing maps, all kinds of options, absolute fine control of the entire engine enviornment. Cost is VERY high though. You're looking at $1500 at the least, and if you add in the (necessary) goodies like wideband and various sensors, you're looking at over $2000. They are kickass, though.
That's pretty must the gyst of it. As you can see, cost goes up as you go down the list, but so does quality. Also note that complexity of use starts at the easiest, and goes to most difficult. For a standalone or even the emanage, expect to have to hire a professional tuner to tune your car on a dyno- which is big bucks if you want it done right. Lots of added cost as you go up in complexity/price-- but of course you're getting quality as well. I had a professionally tuned AEM EMS on my previous KA-T, and the thing ran smooth as glass. Off boost you'd think it was a stock car, on boost it was mean as hell-- and always smooth. Expect less expensive/complicated managment systems to be somewhat rougher around the edges.
This is probably the biggest decision you have to make when putting together this car. Figure out your budget, and my advice is buy the best managment that you can afford. This is where true reliability comes from, so try not to skimp.
