Modified by 2BN_S13 at 3:18 PM 11/13/2004RagingPanda wrote:...the outter part of the stud where the bolt bolts onto
It takes no more than a few fours to pull the diff out and swap the rear cover and put it back in. It should take 2 hour at the max. I think you will be fine of there is 3 bolts still in the back. I personally wouldn't worry about it. If you are paranoid change the cover.RagingPanda wrote:I stripped the outter part of the stud where the bolt bolts onto, not the inside of the diff. It took me like 3 weeks to finally put the diff back on b/c with college and all. I don't want to pull it out again. So how do you pull it out? Just buy one of those thing base9se posted, but the stud doesn't just slide it; it was screwed in. There's a tool that can grap the stub so i can screw it out?
