I;m stumped... how do you replace the headlight bulb?
diego1212
Car: Nissan Versa
i took off the power thing, but now i'm stuck on how to take OUT the bulb so i can put in my new bulb. anyone know how to change it?
diego1212
Car: Nissan Versa
NEVERMIND!i just took the rubber thing off
Ninja40
Car: Versa
What type of bulb did you go with???
Chrispd100
Car: 1977 280Z, 1987 Stanza, 1994 Sentra, 2007 Versa
To remove the head light bulb i had to disconnect the the wire for the bulb itself and then remove the rubber ring that goes on the outside of the bulb. After you remove the rubber piece you should see that there are two little bars that go across each side of the bulb. you have to push them towards the bulb and then push away from the bulb to unlatch it. its kind of a pain if you don't have little ity bitty arms like i do cause its hard to get to them. let me know if that does not help you out!!
