pr240sx »
https://forums.nicoclub.com/pr240sx-u5499.html
Wed Jun 14, 2006 10:05 am
Instead fo checking spark at the coil, try checking for voltage fluctuation (on ~ off) at the coil power connector.you can sin the dist. out and check itIf you have time, try to disassemble the old distributor and clean the pick up inside.Be sure that the ignition module is ok
