I'm so freakin stupid
Shift_Altima
Car: 2008 altima coupe 2.5s 6 speed
I was switching the LED bulbs in the doors. The ones that turn on when u open the door. And i dropped the bulb under the seat. So i figured id take the car off the driveway which is on an incline to get a better position to stick my hand under the seat. Completely forgetting that the plasitc piece was off i slammed the door and bent a piece of metal. Now allllllllll of the lights wont work besides headlights brake lights and dash lights. My trunk light.. glove box light.. map lights.. vanity lights.. door lights.. and rear light won't turn on. I'm gonna tkae it to nissan. I'm so freakin pissed off
kuhan
Car: 2008 Nissan 350Z Enthusiast 6spd
hey man. sometimes we forget stuff. unfortunately, this time it costs ya. that's how we learn from our mistakes.
BTW, you probably popped the 12 VDC fuse the lights
Modified by kuhan at 8:40 PM 2/27/2008
Sensors
Car: 08 2.5 Altima Coupe Code Red CVT
ah that sucks man, good luck with the repair
Shift_Altima
kuhan wrote:hey man. sometimes we forget stuff. unfortunately, this time it costs ya. that's how we learn from our mistakes.
u think i should take it to nissan or fix it on my own? I'm gonna act as if i have no clue what happend and see if they figure it out. Because if i tell them i slammed the door on it they're gonna tell me tough luck ur paying.
johnny_d
Car: 2008 Altima Coupe V6 SE w/ CVT
sounds like you may have just blew a fuse, they can be bought at Walmart for cheap. Good luck.
iam8up
Car: 2008 Nissan Altima 2.5 S
If these guys think the fuse is to blame spend a few bucks to replace all of the fuses. If that doesn't fix it, put the original ones back and then see what the dealership says about it.
Shift_Altima
i scheduled an appt for next tuesday. So let's see what they say.
LongBeachCoupe
Car: 08 Altima Coupe (RIP Hurricane Sandy)
2005 Lexus RX
Hey man.. it could be worse... I was with a friend when he was putting speakers in the door of his new ride... passenger side... and he pulled out of his driveway without closing the door... it completley bent the door around and cost him like $1k.... this is a little light! ull fix it cheap!
Also... remember to use proper lift points! http://elisetalk.com/forums/showthread.php?t=30674
maxentropy
Car: '08 Altima Coupe 3.5SE
iam8up wrote:If these guys think the fuse is to blame spend a few bucks to replace all of the fuses. If that doesn't fix it, put the original ones back and then see what the dealership says about it.
I wouldn't replace all your fuses, just pull each out one by one and take a look to see if any are burnt out. It's very obvious when they are.
Crossing my fingers for ya-- hope it's only a fuse. Good luck!
Shift_Altima
woow long beach those are some nasty pictures. Makes me happy i only messed up the lighting in my car lol. Where's the fuse box guys? I'm pretty clueless about these things
johnny_d
the fuse box is the black box on the right side of the engine bay, it's the L shaped box that's touching the Red positive terminal of the battery
alphapig
Car: Nissan Altima Coupe S 2.5
I ran into this problem as well when installed LED's into my A/C. The fuse popped for some reason.
The fuse box that you are looking for is actually not in the engine bay. It is in the cabin, by the place where the key fob is inserted into.
On the other side of the fuse box cover is a diagram of the fuses and what each does. Find that one that is for interior lighting (or something like that, I can't recall) and replace it with a spare fuse, which is also provided in the fuse box.
Hope that helps...
Shift_Altima
Since i'm gonna go to the dealer anyway to get my clutch replaced for that damn clicking.. seatbelts for squeaking.. maybe glovebox for rattling.. i might as well pretend i have no clue what happend. if that doesnt work ill take u guys' advice and go for a fix. tahnks alot
