WDRacing »
https://forums.nicoclub.com/wdracing-u3125.html
Fri Feb 05, 2010 5:53 am
OEM parts don't fail until you're in the 400's. It's been dyno proven many times, in fact if it's tuned well and the motor is in good shape, the rods don't even bend until over 450.
Forged internals provide a safety net. My recommendation is to go forged if you are looking for more then 350whp. If you're not looking for big power, then there is no real need to upgrade to forged goodies. However, you have the motor apart already. I'd upgrade now, because..well why not. Eagle Rods are cheap and good and any forged piston will work just fine. Basically whatever the best deal is at the time is the way to go. Just get the entire rotating assembly balanced and you'll be good to go.
Once your motor is built, octane will be your only real limiting hurdle left.
Welcome to KAT
WD
