KATwo40 »
https://forums.nicoclub.com/katwo40-u25350.html
Sat Sep 09, 2006 10:21 am
There's a little metal tube that peeks out from under the intake runners, beside the throttlebody. Connected to that tube should be a pretty good size rubber vacuum hose (like 3/8 I.D. or slightly smaller), which runs to your intercooler pipe (probably near the throttlebody, but some people run them to the turbo intake pipe).
This metal tube under the manifold leads to the AACV (controls your idle). Remove the rubber hose and spray throttlebody cleaner down that tube (key off, engine off). Spray so much down it that you get bored.
Then, re-connect the vacuum hose, start the car and let it clear it's throat. It'll chug and smoke like crazy for a few seconds, but keep the revs up around 2,000rpm and it'll clear right out.
Then, let us know how your idle is after that.
By the way, you never did say if your vacuum returned to normal after repairing the leaks.
