float_6969 wrote:- I'm assuming the extra plug (won't plug into anything) by the relay box by the battery is for the detination sensor. (I'm getting a code 34 and it's the only plug I wasn't sure about. How did you guys wire it up? Just splice it into the harnes somewhere? Thats what I was going to do, but I thought I'd see if anyone had a bright idea.
I did a whole write up with pictures on how to wire up the Knock Sensor, just do a search for Code 34 fix or search by all post's made by me. Pretty easy stuff.
Quote »- Is the bolt pattern for the SR MAFS the same as the CA MAFS? I have no air filter right now, but I don't know if an SR MAFS adapter will bolt up. I tried to use my stock airbox, but the bolt pattern is different. [/quote]
My KA adaptor worked for me. Try that out or just get a sheet of Aluminum from Home Depot, cut a square out, drill the holes for the MAF, and weld a 3 inch piece of exhaust tubing to the other end... viola! instant MAF Adaptor.
Quote »- I've got NISMO 550cc injectors, but the ECU can't drive them. Any easy fix to get them to work so I can turn up the boost after I get the new turbo in? [/quote]
S-AFC or have the ECU retuned, no other options really.
Quote »- To those with SPEC clutches. What did you think of the pedal feel? I think it's too light. I'm still breaking it in, so I haven't gotten on it yet, but it doesn't seem to slip, it just seems to easy to push. [/quote]
What Stage? I don't have mine installed yet. Stock clutch is holding up OK for me for now.
Quote »- Anyone have a pressure regulator control Solenoid? I can get one new from Nissan for like $75, but I hate to pay that much. Maybe someone has a better hookup with Nissan than I do. If so the part # is 14956-27M00[/quote]
That little doohickey under the ignitor that goes into the intake pipe? That is for hotstarts, I don't even have mine wired up..... just ditch it, don't need it. No adverse affects here.
Quote »- How did you secure your battery with a FMIC. I got a Slim battery, but I can't think of how to secure it. I may use the stock securing bracket and drill holes to make it work or something. [/quote]
Secure the battery???? hahahah that sounds like doing something the "right way". I have an Interstate Batteries Lawn and Tractor Battery for my FMIC, the length of it is the exact same size as the width of the stock battery, so it is wedged in place in the tray pretty good.... so its not going anywhere.
Quote »It's not 100%, but I think I have a VERY simple way to get the A/C belt to work. If you look closely, the pulleys are the only difference. I bolted mine up and it fit fine. My friend has a tool to take the clutch off of the A/C. If I can get the clutch off, I should be able to switch pulleys witht he CA pump and everything should line up, no problem. But I'll let everyone know if it does work. Anyway, I'm excited and I've written a novel. Thanks for everyones help and I'll keep you all updated. Thanks! [/quote]
Don't know..... ditched my A/C. Talk to Mikey, Alfred's buddy. He kept his A/C.
Congrats on CA power!
Joe
