with my 245 and 40+ I would have cleared a drop with about 10mm left, but with all the bumps and potholes around here it would have been A RUB HELLLongBeachCoupe wrote:I follow the Dr's orders... im out as well kinda dissapointed.. but ohh well...
zerothread/315198desertdragon wrote:Doc, What pictures are you referring to?
Thank you for the link.Wow, that is pretty bad. I had the same issue with my 05 3.5 altima sedan with eibach pro kit drop and 225/45/18 tires on aftermarket wheels. I had to change the plastic guard 2 or 3 times because of the same issue.One time it ripped the whole thing off when I was doing 85 mph on a highway and scared the s*** out of me.mcheddadi wrote:zerothread/315198
That is a very good point. Great observation!IMrGoodBarI wrote:before we go by those pics he does have a after market front and by the looks of it the plastic part looks loose from the bottom. If it was loose before the canyon run that means that it would be rubbing because the wind would push it towards the wheel, which would create the hole.
i thought about 225 tires... I don't think you'll like em! To have only 10mm wider tires... I hate the way the 215mm stock tires drive, another 10mm just wasn't gonna be enough for me... also, when I put the 225 tires up against the rim, I saw that it was gonna look wierd, the rim looks smaller than the tire! 225mm = 8.85" vs 8.5" tiredangeris wrote:I have to agree that although the pics of Blakes fender well is discouraging, I have to be honest that I most likely will not be doing any canyon runs anytime in the near future. I merely drive the car back and forth form work and maybe a little bit of spirited driving. I'm still going for the 1" drop but the rims I want come also in 20x8.5 +35 offset. If I mount 225/35/20s I'll be in the same proportions of stock except the rim will stick out 22.5mm more than stock. Only way to overcome that is to roll the fenders, which I am seriously debating on doing. What do you guys think?
umm, yeah, we all know that, but at what cost... better performance at the expense of a hole in the fender liner???skiski329 wrote:but you all do know that the car will perform better. This is because it is fwd and when we hit the gas not as much weight will go to the rear, our drive tires will have more traction, there will be less wheel spin.
I think you missed the point I was making... if his rubbed with stock wheel and tires with spirited driving, what do you think will happen when your tires sticks out 22.5mm more than stock... then add the 1" drop !!!dangeris wrote:I have to be honest that I most likely will not be doing any canyon runs anytime in the near future. I merely drive the car back and forth form work and maybe a little bit of spirited driving. I'm still going for the 1" drop but the rims I want come also in 20x8.5 +35 offset. If I mount 225/35/20s I'll be in the same proportions of stock except the rim will stick out 22.5mm more than stock.
are you sure you wanna do that...i thought your car was leasedadidas2go wrote:Im just going to cut out an equally sized hole on the right side and put a rubber gromment around the whole outline to make it look like stock brake cooler vents
adidas2go wrote:There is a section of the road that is a 3/4 mile 10 degree right bank turn. I started the turn at 90 mph and ended at 110.
I'd hardly call that sptirited driving, especially in a canyon run, making a 10 degree right bank turn at those speeds... none the less I understand your cause for concern with your wheels though.... I say this only because again, a better/fully built suspension that's geared towards handling autoX and canyon runs wouldnt result in the rub (but I am open to the correction of my mistake, if I have made one) so if/when they become available, the drop will be more positive and effective then just a drop by/with springsrjdmmfl1 wrote:
Blake, I'm gonna try to get up to there sometime over the next few weeks... i really want to check out the drop in person, and see how the suspension holds up going over bumps... you mind meeting up? I'll contact you over email. We may as well invite the rest of the SOCAL crew, I'm sure everyone's dying to see this thing in person... it may help me to make a better decision!adidas2go wrote:Im buying out my lease... Even still to replace those guards is only $30 a piece. My lease is up in a year and a half...
