Pyrokid wrote:Ok, so I was replacing the clutch in my 240 today, and got stuck. I have the resurfaced flywheel, clutch, and pressure plate installed. I've got the new throw-out bearing in the transmission. But, when I went to put the transmission back up it would go back on. I have the input shaft in the spline, and I'm pretty sure the teeth are lined up, but it wouldn't move any closer to the motor now matter how hard I pushed. Any body know any tricks or something I missed that would cause this?
Whenever that happened to me, I used to just wiggle it back and forth, or try and take it out and slide it in again. Take a look around the entire transmission and make sure it isn't hitting anything. Also make sure it is going in straight. Are you putting on the motor inside our outside of the vehicle?
furple wrote:sorry about the noobishness of this question but could someone please explain all the style terms?
like kouki, zenki, chuki, all that stuff.
Ok I thought there was a thread about this somewhere, but I did a quick search and couldn't find it so I'll give you a quick summary.We'll go in chronological order.Pignose: Original 240sx (S-chassis) design. Part of the S13 family. Denoted by the split front bumper. Came with a SOHC 2.4l Inline 4 cylinder engine in the US. (Production years 89 and 90)Chuki Also known as shark nose. The second of the S13 family. Production years 91-94 (only convertable sold in 94). Came with DOHC I4 2.4l engine in the US.ZenkiProduction years 95-96. Also came with the same DOHC I4 2.4l engine. No longer offered in hatchback. The style of the "S14". Characterised by its rounded headlights that often get cloudy or yellow.Kouki Production years 97&98. The second S14 style. Still came with the DOHC I4 2.4l engien (KA24DE). Characterised by its mean looking angled headlights.
nwmrkt wrote:prepare for one of the most "noob" questions to be asked, pardon me please.
Anyways I think my rear brakes or fronts are seized...to double check just jack the car up and try to spin them?
Also to double check...whats the proper way to jack the car up so I can spin the front/rear wheels...etc is it okay if I just jack it from the rear diff until the two rear wheels are off of the ground, and chock the front ones? Or should I go by it by another way?
Thanks
Yeah, you can jack it up and try to spin the wheel. You can also take it for an easy ride around, and then feel each brake (CAREFULLY). The one that is seized should be hot as a mofo.
To jack it up- Yeah, you can jack it up by the rear pumpkin. It is highly reccommended you use jack stands. Front- I always go by the front cross member. I have also gone by the bottom control arm. GL.
