progman »
https://forums.nicoclub.com/progman-u42503.html
Fri Oct 01, 2010 12:04 pm
DEEP,
I run a megasquirt as well. The relay kit is for converting a car from carb to EFI (and for neat freaks!). With the CA18 the only relay you need is the fuel pump and it takes 3 seconds to hookup. If you assemble the kit your self buy a decent solder station I don't recommend using a regular pen solder stick thing (but people have done this).
DEEP, also for the 1995-1998 KA24DE you have have to change the ignition... ether do a trigger wheel (lots of work) or convert it to the 91-94 ignition system.
have fun.
