forecast »
https://forums.nicoclub.com/forecast-u7026.html
Tue Aug 19, 2003 8:03 am
Wow the pace of life on this forum is insane. I spent yesterday by the pool trying to soak up the end of summer and I miss so much!
I'll answer your questions in reverse.
No, I wouldn't do it again. Well maybe. It was a lot of fun, but not the most effective method. I learned a ton and really bonded with my car. I'd do an engine swap today though since it would be faster and cheaper.
I went this route because at the time it seemed like the only option. I didn't have a clue how to source a working pullout and I wasn't ready to let the car go.
I memorized the engine rebuild section in the little Q bible before I started. I have rebuilt other engines before, but never a V8.
I had the heads ground, resurfaced, cylinders honed, crank welded and gound.
$1700 at the machine shop, $500 in parts $500 in rings and gaskets, a few hundred in misc tools.
I let the machine shop measure everything with micrometers and tell me what was within spec and what needed replaced. I reused the crank.
Everything came from Scottsdale except the rings and gasket kit.
