Wulfgang »
https://forums.nicoclub.com/wulfgang-u10889.html
Fri Mar 26, 2004 7:54 am
You haven't installed this yet, have you? If this works, then my tape measure must be wrong (or maybe it was operator error on my part). If you used the RB bellhousing with the KA rear case, then by my measurements, your shifter will be 2" farther back than the center of the hole. That will take it right to the edge of the hole, and you will be forced to do some cutting if you intend to use 2nd, 4th, and reverse.
If you are using custom mounts that move the engine back 1/2" or so, your shifter won't even be in the hole at all.
I also do not expect your transmission mounts to line up or your driveshaft to fit. Sorry to be all doom and gloom, but I don't think this will work.
Let me know if this isn't true, so I can pitch my tape measure in the trash.
