I'm going to either shoot me or the car
Sircnay
Car: EVERYTHING
Okay, so I got into a small wreck 3 weeks ago that totalled my suspension, i have pictures, the T/C rod snapped, the control arms bent, the rear strut went kaboom. Anyhoo, fixed all that, only took me a good 13 hours to do. Felt good afterwards. I also not only had to replace the suspension but I also had to get new rims, so I talked to a local import shop and managed to get the guy to bring the price of the Nippon Racing Type-C (the SSR looking ones) from $1200 down to $650, as the rims have been sitting there for about 1 year with no sale.
Anyway, so today after finally getting those damned tuner lugs and putting my rims on finally I took my baby out for a ride. Everything was running perfect, the turbo was spooling just right, everything. Got her some 91 octane and went home. On the way home the whore decided to stop running. It started sputtering like as if an intercooler pipe came off. So I figure okay, i've dealt with this before. So I go check it out. Nothing, not the intercooler pipes.
The following is what I've ruled out:-Fuel pump, it's still working. Fuel is still getting to the injectors because I pulled the fuel filter hose and gas was being pumped out. -Injectors, the car starts but then starts to roughly idle and die.-Sparks, if the car starts, these suckers are working-Bad gas, I'm a Texahoe user
What else could it be? It was running fine and seriously the next second it dies. AGH! So now it's sitting in the parking lot of a supermarket. *sigh*
ride4lame
check the mafs connection
Cyberkreig
Car: 1993 Nissan 240SX SR
You know what is odd? I got a tank of 93 octain from sunoco the other day and i am having a VERY similar problem. The car simply does not want to boost. Bucks/studders/misfires.
I know that doesnt help you much. but it is possible that it is just bad gas.. and it always feels better to know you arent alone
Sircnay
Car: EVERYTHING
Figured it out. Turns out that the wire that most people wire up as a "kill switch" under the steering column came loose from it's connecting source. Now it boosts just fine except for the stupid exhaust leak i'm having. Grr... soo much to fix and so stressful.... *sigh*
