I'm getting no power to fuel control unit, please help!!!!!!!
Q45dude
Car: 94 Q45
Hi,
My fuel pump was humming for a while and it eventually went out. I bought a new (junkyard) a fuel pump and also a fuel control unit from Ebay with DOA guarantee. I exchanged the fuel pump but now I'm not getting power to get it running. I tried both fuel control pumps and seems as though no power it coming to them to get the fuel pump going.I gave the fuel pump direct power through some wires and was able to start the car.Anything else I'm missing here? Are there any relays or fuses which could lead to this??Need help ASAP guys, I've been w/out a car for about 2 weeks now and I miss my Q45.
Thanks guys.
Jeff Williams
Car: 1994 Infiniti Q45t
2000 Infiniti I30t
2004 Infiniti M45
71, 72, 73, 82 & 2000 Corvettes
There is a fuel pump fuse under the dash. Check it with a meter, to see if 12 VDC is going through it.
Also check to see if you are getting 12 VDC to the controller. The output to the pump should be variable voltage, but 12 VDC at start-up.
Usually, when I have these problems, it is because I forgot to re-set the fuse, or re-connect a wiring harness.
There are some great threads on fuel pum controller and fuel pump in here and the Infiniti Online Mechanic Forum.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
DOA = Dead On Arrival (!!!?), so I don't get it.
Using a used fuel pump is asking for someone else's problem. It is cheap enough from Joe to avoid the extra labor and problems you will encounter sooner with a used one. Did you inspect the tank? Change the fuel pump booty sock? The fuel filter?
Do you have a FSM? Must understand how the power is routed and the voltage is switched.
Q45dude
Car: 94 Q45
thanks for your replies. But I'm still in the dark hole here.Does anything need to be reset after replacing fuel pump and Fuel controller? (disconnect battery and reconnect or something for the ECU to reprogram???)All fuses under the hood are okay when checked, (I had the key to ignition and tested all fuses and the little light bulb would come on) so I know they're all good.How about the connector to the FCU?? anything might be burned or melted there or what??
I need alot of help in great details please.
THANKS
Q45dude
Car: 94 Q45
Jeff,
how do you re-set the fuse??
thanks
I was told [and I could be remembering what I was told incorrently] that there is a relay somewhere around the back on the sides of the trunk above the rear wheels that can cause this problem. I wish I knew more so I could elaborate.
Q45dude
Car: 94 Q45
Thanks Jesda,
I'll look for it and hopefully that'll be it. (after work offcourse).I'll keep you posted.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Q45dude wrote:how do you re-set the fuse??
You reinstall it after installing the pump.
Q45dude
Car: 94 Q45
thanks.
Q45dude
Car: 94 Q45
Okay guys....... finally got the job done. Damm I missed my Qee.The fuel pump relay by the right rear wheel was bad. $14 and it did the job.
Thanks for all your helps.
