carlos15 wrote:what will hapen if you put them in the wrong angle??
I don't think anything will really happen, it will just look stupid probably. You could put them on straight if you wanted to I guess. They are supposed to Reduce Overall Aerodynamic Drag, Reduce Rear-end Air Flow Separation, Reduce Turbulent Air Flow, Allows For Faster Clean Air at Rear End ( according to their website ). So for that to happen they need to be at the angles they provide.
The back of the box is a diagram with the degrees on the back of it and it tells you which ones need to be at which angle. If you need anything else just let me know.
VersaMG08 wrote:Do they make a noticable difference?
I haven't noticed anything, but than again I didn't plan on it. I think they look cool though..
