Nismo_Freak wrote:Hahhaha... you think a VG30DETT swap is going to be so much easier?
shlt, trying to do a vg swap will make you even more stressed out bro. im with everyone on saying to go get a good tune. i get a boner every morning just from dreaming of what my kat will be like and im not even turbo yet. you cant drive the car 45 mins?Florida240sx wrote:Thinks happen for a reason....First engine I thought it was a sign to check twice run it once. So now this could be jsut a little car common gremlin, which I can fix this weekend. OR to me it's a sign of get the d@mn KA out of me and put in something bigger.I already know how hard the vg swap will be. Reason why I'm buying a welder, torch, and other goodies. I'm stressed out. I need something that will keep me thinking, not running in circles....
Huh??? You corrected for 550cc with the SAFC? Now you can't get the timing right. The SAFC might be problem 1. Altering MAF signal fools the ECU into thinking there is a lighter load on the motor. This causes it to advance timing. Alos, getting the timing set for a turbo can be a bear.Florida240sx wrote:I got tomei 555CC. But have had timing gremlins. Replacing the rotor on Sunday. Only thing I haven't done. I have a safc and a lc-1 wideband.
If your running normal suction maf on the intake side of the turbo and your valve cover breather hose is hooked to the turbo intake side, it sounds like you popped some ring lands.Florida240sx wrote:OIL all over my new z32 MAFS can't figure out where, was dripping out of my filter.......
